Carbon Lip at the Top of the Cylinder Gead
Old Dec 17, 2017 | 03:48 PM
LADisco2's Avatar
Default Carbon Lip at the Top of the Cylinder Gead
A description of the cleaning of the piston heads prior to installing new head gaskets included this warning: "be careful you do not break off the carbon lip at the top of the cylinder sleeve."
The description comes from a long, detailed tutorial on head gasket replacement on the Bosch 4.0 engine of a Range Rover P38. What is the carbon lip?
Old Dec 18, 2017 | 10:54 AM
OffroadFrance's Avatar
X1 .......... too true, unless you are honing the bores and replacing the piston rings the carbon bore step is best left to seal at TDC.
Old Dec 18, 2017 | 02:12 PM
abran's Avatar
Just don't touch the cylinder walls. Use a honing stone on the block mating surface(the fine side) but don't go past the flat mating surface.
whoman101
Apr 23, 2012 09:20 PM
tommytwotone
Sep 22, 2009 05:09 PM
Rover Kid
Member Group And Special Buys
Dec 4, 2008 06:52 PM
cosmickites
Defender
Oct 14, 2008 08:40 AM
