Carfax 2004 Discovery
Hello again, I pulled up a Carfax file of a 04 and the Land Rover dealer did the following:
Service contract claim
Fuel system serviced
Engine serviced
Drive axle serviced
Maintenance inspection completed
Engine/powertrain computer/module checked
Air flow meter replaced
Oil pan gasket replaced
Intake manifold gasket replaced
Is this good? Should I need to worry about the drive shafts? Since its serviced?
Thanks my friends!
Engine serviced
Drive axle serviced
Thanks my friends!
The factory front driveshaft will last anywhere from 80-100,000 miles, and then when it breaks it also takes your $7,000 transmission with it.
If it does not have greasable u-joints then this is something that you want done TODAY, it will set you back about $200 and any shop that does u-joints can do the work.
The LR dealer will just sell you another LR driveshaft without the grease fittings for $800.
And yes, grease them at every oil change.
