Carparts.com wheel bearings
Old Sep 1, 2020 | 08:52 PM
SundayFunday's Avatar
Default Carparts.com wheel bearings
Anyone using these wheel bearings?
Clearly a cheap try here - anyone have anything to report?
Old Sep 1, 2020 | 09:45 PM
redwhitekat's Avatar
I think the forum folks have stayed away from cheap bearings Buy a good quality name brand oem. Why go cheap on that
Old Sep 1, 2020 | 10:01 PM
have you used them?
Old Sep 2, 2020 | 01:33 AM
User's Avatar
Originally Posted by SundayFunday
have you used them?
Need a better reason?
Old Sep 2, 2020 | 03:02 AM
JUKE179r's Avatar
Not to disrespect anyone's mechanical capabilities, but... when some says brand "X" hub (or any part really) is faulty but you later find out:
- they didn't follow any steps in the RAVE manual
- they didn't clean the drive shaft splines, wheel hub and axle mating faces
- they didn't tighten the bolts securing wheel hub to axle to 100 Nm
- they reused the old hub nut and didn't properly tighten it to 490 Nm...
Can they really fault the manufacturer of the hub?
Old Sep 2, 2020 | 06:41 AM
have you used them?
I have never done bearings but just from reading the forum for the last few years that’s the reviews you get
now the cheap eBay radiators seem to work just fine
Old Sep 2, 2020 | 10:42 AM
Best4x4's Avatar
I've installed plenty of no name Ebay hubs onto D2's. I've yet to have any of those friends/customers come back with a 2 or 3 wheeled D2. I had one come back with a torn off lug due to a tire shop, but I don't really see that as an Ebay hub issue as Tire Shops can destroy lugs pretty easy if they're clueless.
Old Sep 2, 2020 | 04:31 PM
TexasLandmark's Avatar
Wheel bearings, u-joints, tie rods, water pumps, and tires are things that I won't cheap out on. A *properly installed* chinese bearing may be fine... but a good usa, german, or japanese bearing will always be fine. Doubt anyone can give a direct review of those because you never no what no name supplier part that you'll get.
zuke
May 26, 2020 09:16 AM
Chris-bob
Feb 4, 2011 08:55 PM
fivecornersmike
Nov 10, 2010 07:44 AM
NiveK1970
28
Nov 24, 2009 11:41 PM
bklahl
Oct 12, 2006 04:38 PM
