Wheel bearings / hubs
Old May 26, 2020 | 05:27 AM
zuke's Avatar
Default Wheel bearings / hubs
So I got a bad bearing on a front wheel. Looking for parts I only found the entire hub assembly for sale so I picked up the britpart unit for $170. I saw cheaper ones but wanted something I could trust.
Has anybody changed out just the bearings?
Old May 26, 2020 | 06:40 AM
mollusc's Avatar
The cheaper ones (like, maybe $85 on eBay) are just fine, as should be the one you got.
It's a simple operation to change the whole hub, Is there a reason you would want to change just the bearings?
Old May 26, 2020 | 08:49 AM
JUKE179r's Avatar
Don't forget to purchase new hub nut to be torqued at 360 ft lbs.
Old May 26, 2020 | 08:56 AM
XRAD's Avatar
and some of the 'new' axle nuts are oversized on the facets which can be an extra hassle if you need the socket.
Old May 26, 2020 | 09:16 AM
JUKE179r's Avatar
Thanks @XRAD . I forgot about this. My new larger hub nuts required a 36mm socket vs. the 1 1/4" socket.
patagucci
Sep 13, 2019 09:19 PM
dms6601
Oct 13, 2013 01:20 PM
lilherc
Apr 17, 2013 06:23 AM
tonydiscovery
Jan 14, 2012 02:25 AM
Chris-bob
Feb 4, 2011 08:55 PM
