Castor Correct Radius Arms vs. New Bushes
Old Apr 6, 2017 | 04:32 PM
dtmbinb's Avatar
I just installed RTE 3° corrected arms. The highway steering is night and day. Feels like stock now above 60 mph. The correction did effect the pinion angle of the front diff, so I now have vibrations from the Lucky 8 drive shaft. A HD drive shaft from GBR should arrive tomorrow, and I believe will cure the vibrations. Should be smooth sailing on road trips now!
Old Apr 11, 2017 | 03:45 PM
Jeff Blake's Avatar
FYI... I took my Terrafirma arms and Allmakes standard bushings to my shop, and he said the 4 bushings from arm to axle are not going to fit. He said they might fit if he chamfers the bushing, but is not optimistic. I think I agree with him.
I put in an inquiry to Terrafirma to figure out what to do. Maybe they are meant for poly's.. but I can't see the size being different. If anyone has any ideas let me know
Old Apr 12, 2017 | 02:16 AM
chubbs878's Avatar
I think the TF arms do require poly bush; there is a thread. You can call Lucky8 & they will confirm. I remember seeing the bright orange bush Lucky8 installs to these arms before shipping them out.
Old Apr 12, 2017 | 10:58 AM
ZGPhoto's Avatar
TF arms are supposed to take either. I had standard bushings in mine.
Old Apr 12, 2017 | 11:18 AM
Jeff Blake's Avatar
Thats what I thought. How did you get the bushings in? Genuine or? The axle side bushes are a good 2-4 mm wider all around.. i.e. 4-6 mm wider in diameter. If I put them in a press they'd just squish and shatter the bush...
i might try the britpart poly set for about 65 bucks, they may be worse than rubber, but that's one less thing I have to depend on a shop for. I've practically rebuilt the whole car at this point and only needed a machinist (top hats, valve job), and a tire shop to mount tires.
why terrafirma doesn't put bushes in these like they do all their other components is annoying.
Old Apr 12, 2017 | 11:40 AM
dtmbinb's Avatar
I went with poly in my RTE arms because RTE called and said the oe bushings they ordered wouldn't fit either. Maybe there was a bad batch put out recently. They said the oe bushes were too large to press in. They had poly in stock and I didn't want to wait. So far, I'm really pleased with the poly.
Old Apr 12, 2017 | 01:14 PM
Motorhead1's Avatar
waaay back when I used replace a lot of track arm bushings in our heavy equipment, we had a "socket" style tool that you use with the press. You pressed the new bushing down through, and the socket would squeeze/choke the bushing and allow it to slide (with wd40 lube) into the arm. Otherwise you would NEVER get a rubber bushing to press into something, or you would die trying??
Old Apr 12, 2017 | 01:45 PM
ZGPhoto's Avatar
I put genuine bushings in mine, wasn't an issue at the time, but that was around 4 years ago
coors
Dec 31, 2019 04:26 PM
cybercop
Jan 28, 2015 11:23 AM
badfysh
Oct 23, 2012 10:45 PM
LeakyDisco
Jun 14, 2011 11:32 PM
welling4x4
Sep 29, 2010 11:15 AM
