Cat converter question
Okay, I managed to get the Service Engine light off, but today the Check Engine light came on. Read the codes with my newly aquired OBDII reader and I come back with P1314 and P1313, which I understand are for the Cat Converters. I reset the CEL and drove around for a bit, and the light has stayed off. My question is, should I just plan on replacing the cats? And do I need to replace the O2 sensors (or anything else) while I'm at it, even if I'm not getting any codes coming up for them?
Regards,
Joe Martin
P.S. It's a 98 Disco, with 179k (only 50k on the engine)
Regards,
Joe Martin
Magnaflow makes some good high flow replacements. I had some welded in instead of replacing with the $700 entire Y pipe. If your O2's are original, you are due. All 4 at the same time. The $$ you save on the cats will justify the O2's for your pocketbook. Magnaflow has a list of dealers if you don't have a muffler shop you are familiar with.
on
Need to quote the fault codes correctly, they are misfire/cat damage fault codes for each bank, not related to a cylinder misfire or you would also have either or a 300 and a 1300 misfire code.
Change out your tired cats that were probably damaged by the original engine, possibily coolant contamination and replace the 02's which although they are not faulting, they are very limited as to the ability to set proper air fuel mixtures.
elboy0712
12-19-2010 02:48 PM
mathis_m1a1
01-09-2007 05:11 PM
