Witts end!! Wont unock..
Old May 15, 2009 | 03:08 PM
hollis's Avatar
Default Witts end!! Wont unock..
I think my truck is super locked but cannot figue how to unlock it. I have tried an new actuator, new battery in the fob, checked the fuses, tried the inertia switch. How do I check my fuse box and which one do I need to check? Under the dash or in the engine? What am I looking for?
Neither the fob or the interiot switch work to open the car.. only locks. Only the driver door unlocks using the handle. No other door will open. Thanks!
Im going crazy here!! I have searched a bunch, but cannot find anything that works!
Old May 15, 2009 | 03:16 PM
How can you replace an actuator when the door won't open?
Have you tried removing the inner door panel, as far as you can and reaching the lock?
Old May 15, 2009 | 03:25 PM
hollis's Avatar
I can unlock the driver door using the key but that is it.. I got a actuator but when I hooked it up to the cable to test it, nothing different happened.. Driver side will lock, and the others sound like theyare locking, but nothing unlocks...
I did have a problem in the past with the back cargo door not unlocking... could this be affecting anything? It happened a couple of times the never again..
Old May 15, 2009 | 03:53 PM
hollis's Avatar
" Only the driver door unlocks using the handle. No other door will open." from above...^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^
thanks in advance!
Old May 15, 2009 | 03:58 PM
If you pull up on the passenger door lock and try to open the door will it open?
Old May 15, 2009 | 06:44 PM
hollis's Avatar
no none of the other doors will open from the inside using the handle except the drivers....
Old May 15, 2009 | 07:25 PM
I think you mis understood me.
Or maybe I am mis understanding you.
Have your wife stand outside the truck, you climb into the passenger seat and pull up on the door lock, NOT the door handle but the little thingy that moves up and down to lock/unlock the door.
While you are holding that up have your wife try and open the door from the outside.
Old May 16, 2009 | 03:47 AM
hollis's Avatar
oh ok.... nope.. the door wont open and the lock just springs back down... i tried it on the passenger door...
Old May 16, 2009 | 06:49 AM
tarvc's Avatar
4th Gear
I have the exact same problem. Happened last night as I was leaving work to head home (Great way to start the weekend). Anyway, I had mine (04 Disco) towed to the dealer (after my wife brought me the spare key / remote to try - no luck). The tow driver & I left it right in front of the service door so I sould hear today what the problem with mine is. I will post a message once I get some definitive info.
Old May 16, 2009 | 12:32 PM
hollis's Avatar
I heard on here that it might be the fuse box? can someone tell me which one to check?
also, what is the correct way to turn off superlock? I havent found a post through the search that actually just says it! Thanks!
