cause of new oil leak?
Old May 16, 2018 | 04:20 PM
BowRat's Avatar
Default cause of new oil leak?
Hi, just last week my Disco started misfiring on cylinder 5 and 8. It was pretty severe - the SES started flashing intermittently, but it's been parked since.
Over the past few days, a number of large (quarter size) oil spots have appeared, covering an area about 2' square. My truck did have the oil pump alignment service bulletin, but was fixed by the LR dealer in '04.
Any thoughts or ideas on the cause of this? The engine had been oily in the past, but not to the point that it dripped on the ground.
I appreciate any help. Thanks!
Old May 17, 2018 | 07:49 AM
Saturnine's Avatar
Look and see where the leak is coming from? Where are the spots in relation to where the truck is parked?
Observe, diagnose and then repair. This isn’t rocket science
Old May 17, 2018 | 01:29 PM
BowRat's Avatar
Thanks for the reply - as I noted in my post, the oil spots are in an area of approximately 2'x2', so pinpointing the source of the leak or leaks isn't really possible. I suppose I could buy some dye to narrow it down to a smaller area.
I've had the DII for 13 years, and I've never had an oil leak that I couldn't locate the source.
I was just wondering if the sudden leak could be related to the cylinder misfires in some way - blown gasket caused by the misfires - a total coincidence - whatever.
Old May 17, 2018 | 01:40 PM
Dave03S's Avatar
If you've had it 13 years then you would know the history... Have the HG's ever been replaced? You're time could be up. Other areas to consider are front cover and oil filter area. Any work done recently? If so check those areas.
Old May 17, 2018 | 02:28 PM
Sixpack577's Avatar
Common oil leaks are from the valve covers, rear lower intake manifold, timing cover, oil pan, rear main seal and cruciform seals. As well as power steering fluid from the pump.
Old May 17, 2018 | 02:36 PM
Friday Night Disco's Avatar
Originally Posted by Sixpack577
Common oil leaks are from the valve covers, oil filter, rear lower intake manifold, timing cover, oil pan, oil drain, rear main seal, transmissions, differentials, transfer case, high pressure hose, oil pump, and cruciform seals. As well as power steering fluid from the pump.
fixed
Old May 17, 2018 | 02:40 PM
Sixpack577's Avatar
Originally Posted by Friday Night Disco
fixed
lol, yep
If it's not leaking...it must be empty.
Old May 17, 2018 | 04:52 PM
BowRat's Avatar
Yes, I've had the truck that long, I've never replaced the head gaskets.
I had the oil and filfil changed about two weeks ago. I'll check the filter and plug. Would the drain hole leak if they left the washer off the plug? I know it's supposed to be changed with every oil change, but I doubt a quick change place would do that.
​​​​Had an overheat scare about a month ago, replaced the thermostat, it was stuck closed, no problems after that.
There's nothing else I can think of.
Over the years I've replaced a lot of the ancillary parts.
I'll tighten up the valve cover gaskets and whatever else could be loose.
The thing that I don't understand is why it happened so suddenly. Up until 3-4 days ago, it didn't leak at all.
Old May 17, 2018 | 05:54 PM
Dave03S's Avatar
I'd be suspicious of the quick lube place. Start there.
Old May 17, 2018 | 06:06 PM
BowRat - Do the following...get some kind of engine cleaner and clean the engine. Then, start to look around for any NEW traces of oil.
The misfires, well...that could be something related but, let's start with the low cost easy approach first.
