cause of new oil leak?
Old May 17, 2018 | 06:33 PM
BowRat's Avatar
I'm too myself under the truck and see how right the plug and filter are.
I do have some purple power cleaner-degreaser that I've had good luck with in the past.
I'll check those things and report what I've found.
Thanks!
Old May 18, 2018 | 03:07 PM
OverRover's Avatar
Would the drain hole leak if they left the washer off the plug? I know it's supposed to be changed with every oil change, but I doubt a quick change place would do that.
Yes, the Oil drain plug (LSF100040L) requires washer (ALU1403L) to seal.
These threads are NOT tapered (NPT or BSPT), so you need the washer.
Old May 18, 2018 | 03:38 PM
OffroadFrance's Avatar
Have you replaced the crankcase breather or is it blocked? If the crankcase breather is blocked it will force oil from the various oil seals.
Put some newspaper or brown paper under the truck and then check the colour of the oil but don't forget to anchor the paper down with some rocks in each corner.
Old May 18, 2018 | 05:25 PM
Extinct's Avatar
THIS!!! I can almost guarantee it is this or the power steering pump finally gave up. If the spot is left front of engine it is power steering dead center or anywhere else I can almost guarantee it is a blocked breather. The running oil level is below the oil pan gasket, so nothing should leak unless there is pressure blowing it out. The only exception is the crucifix seals which are under pressure, and they seep more than they leak.
taylorm334
Jan 12, 2023 02:06 PM
Nats01disco
Apr 21, 2018 04:37 PM
ToddD
Mar 25, 2015 04:53 PM
EVN137
Nov 24, 2014 07:31 AM
Phatrowles
Jan 9, 2014 10:36 AM
