CB Antenna Mounting Question and RSS
Old Jan 4, 2011 | 07:08 PM
humroot's Avatar
Default CB Antenna Mounting Question and RSS
Hey Guys,
Got a quick question about how you all mounted your CB antenna. Mine is mounted on the spare tire mount. It sticks out above the roofline about a foot. I checked it with a SWR meter and am in the red on all channels (1, 19 and 40). This typically indicates a short or something in the cable. I did some troubleshooting and found that the cable is fine. I checked an all in one radio shack antenna and it worked well on the roof. When I took the antennae off the spare mount and held it up on the roof rack, the SWR meter read perfect. So the question is, do I need to worry about damage to the CB if I keep the antenna on the spare mount? Also, do any of you guys have this problem?
On a side note, I had this forum on my Yahoo page through RSS. Anyone else having issues seing the content?
Thanks for the help!
Old Jan 5, 2011 | 08:54 AM
Long Haul's Avatar
Never had that problem with my CB before on any of my vehicles. I would make sure your getting a good ground and if need be they make antennas with a seperate ground wire. If you keep running the radio like that its not gonna last very long or work very well either, unless you have a Galaxy radio (they will automatically compensate for bad SWR). I have my antenna on my spare tire mount also but it reads the same swr on the roof or the spare tire mount
Old Jan 5, 2011 | 08:57 AM
I would say your CB will not handle that sort of load and will fail with much use.
Old Mar 29, 2011 | 09:51 PM
ernestog's Avatar
Default CB antenna info?
Can you tell me what kind of antenna, length and mount type you are using? I am about to purchase and install a CB in my 2003 disco
Old Mar 30, 2011 | 09:36 AM
Disco_Fever's Avatar
Originally Posted by humroot
Hey Guys,
How long is your antenna? You may not be far enough above the roofline. I use a 4' Wilson fiberglass antenna with a matched 18ft Wilson coax and haven't had a problem in the roughly 2 years it's been installed.
tfmmai
Oct 21, 2014 09:03 PM
BayerischeDisco
Audio/Visual Electronics
Apr 21, 2013 10:41 AM
jpmiller
Jul 24, 2012 07:02 AM
MiamiC70
Jun 21, 2011 02:07 PM
humroot
Jun 22, 2008 11:23 AM
