disco II 1999 front drive shaft..
Old Mar 29, 2011 | 11:20 PM
jcserna's Avatar
3rd Gear
Default disco II 1999 front drive shaft..
I just bay a discoII 1999 and i instal the front drive shaft. new. but i have a problem wen i drive over 70 mph. start shacking. any help. and how i kent drive it whit the back shaft only it is posible. thanks....
i lost alat time in it an money.......
Old Mar 29, 2011 | 11:35 PM
ljdiscovery's Avatar
Yes, you can drive your 99 with the front drive shaft removed. You will need to remove the front drive shaft and lock the center differential. There are a number of threads on the forum on how to find and lock. There is a small 10 mm nut as I recall on top of the transfer case just above the front output and just to the center. It will click about 1/4 turn. Good luck. Phil
Old Mar 29, 2011 | 11:52 PM
jcserna's Avatar
3rd Gear
phil many thanks.
any idea whay is this bibration over 70 mph. the drive shaft is new an is balanced.??
thanks
Old Mar 30, 2011 | 12:04 AM
sorry, I didn't read your post as well as I should have. You may have tires that are over/under inflated, bad shocks, tires that aren't balanced, rear drive shaft issues, front drive shaft issues (although it sounds like you have a new one installed) or the rear rotoflex. Good luck. Phil
Old Mar 30, 2011 | 11:40 AM
sloan74's Avatar
When was the last time you had your tires balanced and a front wheel alignment done?
DiscoJon
Jul 14, 2019 01:51 PM
RSPTex
Aug 3, 2014 11:43 AM
TripleThreat
Apr 12, 2011 08:58 AM
Night Train
Nov 28, 2008 11:17 AM
yarddawg
May 24, 2007 01:54 PM
