Antenna Install W/ Pics and a Question
Old Jun 21, 2008 | 05:28 PM
humroot's Avatar
Default Antenna Install W/ Pics and a Question
I got some questions about the antenna install and figured I would post some pics of the install. Also, I'm getting ready to install the CB and was wondering if I can splice into the brown power wire under the steering wheel. Any thoughts?
[IMG]local://upfiles/7095/373C7D41CCB348C29455F06BE467EA4D.jpg[/IMG]
[IMG]local://upfiles/7095/1BA4F9721FE746FDB05B19FF7624E017.jpg[/IMG]
Old Jun 21, 2008 | 05:53 PM
Default RE: Antenna Install W/ Pics and a Question
Not sure about the brown wire, but can you plug into the fuse box? Maybe if you could hook into the stereo fuse it would turn on and off with the key.
Old Jun 21, 2008 | 07:35 PM
Never plug into a wire. Go direct to the fuse box at the battery so you don't screw up some other componet plus it will make for a lot quieter CB
Old Jun 22, 2008 | 12:52 AM
Disco2Guy's Avatar
I have pics of my install. Power runs from the battery and inside the truck through a rubber grommet in the firewall. Near the battery are a few ground connections you can connect to.
Old Jun 22, 2008 | 01:34 AM
Urban Panzer's Avatar
Interesting this is, I tried a spare wheel mount for my CB, but could not get a good SWR reading at all !!! even added 2 additional grounds, 1 to the roof and 1 to the chassis, still no good !! [:@] so gave up and use a mag mount now SWR reading of 1.2 with that
Old Jun 22, 2008 | 07:48 AM
humroot's Avatar
Cool pix! Thanks for the info, guys.
Old Jun 22, 2008 | 11:23 AM
Disco2Guy's Avatar
UrbanPanzer, you should try a NGP (No Ground Plane) CB setup. The ground is in the coax itself so there's no need to add any grounds. I got my NGP antenna through Firestik.
thehun
Mar 7, 2013 01:35 AM
wheelgarage
Audio/Visual Electronics
Sep 21, 2012 12:41 PM
Torancis_LR
Aug 14, 2009 01:51 PM
Wildhorse1966
Apr 23, 2009 04:17 PM
evoasis
Jun 3, 2006 04:31 PM
