CB antenna tire mount
Old Nov 19, 2007 | 04:21 PM
willlane's Avatar
Default CB antenna tire mount
Hello, I keep seeing that a good place is the tire rack. I have the http://www.firestik.com/Catalog/SS-174.htm SS174 mount...but where on the tire bracket does this go? Do I need to remove the tire so the antenna sticks up behind the tire?
-will
Old Nov 19, 2007 | 05:04 PM
Default RE: CB antenna tire mount
You will need to remove the spare to install that mount, good choice by the way, but once installed you can run a fire stick or similiar antenna. You might consider using a quick disconnect so you can remove the antenna when not needed.
Old Nov 19, 2007 | 05:38 PM
willlane's Avatar
Will I have to drill new holes?
Old Nov 19, 2007 | 07:09 PM
That will be up to you, but for a clean installation you will need to run a line thru the outer door panel, then past the hinges and thru the truck to where ever you are planning to locate your radio.
Old Nov 19, 2007 | 09:21 PM
willlane's Avatar
I ran it to the hood mount. Looks cool that way to me...ran the cable into a grommet just above where the cruise vacuum comes in.
nashville rookie
Jul 23, 2012 03:41 PM
humroot
Jun 20, 2008 08:19 PM
sayre05
Apr 28, 2008 12:32 PM
Disco2Guy
Apr 7, 2008 11:58 AM
HerbD
Jun 14, 2006 02:52 AM
