Cdl
Old Aug 1, 2011 | 10:30 PM
Kalel's Avatar
Default Cdl
I am sure someone has asked this, but does the 2003 have the CDL in the T-case or do I need to buy a 2004 with the linkage?
I have been wheeling for almost 25 years, but this is the first Rover I have ever wheeled.
Old Aug 1, 2011 | 10:38 PM
yloDiscoII's Avatar
Yes someone has asked this
Here you go! Good luck!! --->2003CDLInstall - LAND ROVER CLUB V.I.
Old Aug 1, 2011 | 10:47 PM
Kalel's Avatar
Thanks, Now I have to go buy one. I plan to wheel it a bit before spending the cash on a new T-case.
Old Aug 2, 2011 | 08:34 AM
If you had read Josh's write up you would see that your case can be modified, adding the CDL and linkage.
Before you do anything check your front drive shaft, making sure there is 1 grease fitting on all 3 u-joints or rebuild it adding a new centering ball at the same time.
Then consider following my major service list posted at the top of the D2 section.
Old Aug 2, 2011 | 11:31 AM
Kalel's Avatar
I have replaced the front driveshaft with one that has been rebuilt, $225, with serviceable grease fittings and a new centering ball. I am working on the services you have laid out Mike. It only has 90k miles on it and I guess the T-case is in good shape, so I could save some cash by just doing the front swap. It is not my everyday driver, 2011 Sorento with CDL :P, so if it is down for a couple of days it is no big deal.
Old Aug 2, 2011 | 12:22 PM
DiscoRover007's Avatar
You should be able to get the cdl linkage and front housing from ashcroft for about $500 all together. I believe they are based off the 2004 Disco.
Old Aug 2, 2011 | 12:31 PM
Kalel's Avatar
Thanks, I will try them.
Old Aug 2, 2011 | 12:36 PM
Kalel's Avatar
Just looked it up, for 379.99 I can get the complete kit from Toddco Suspension.
Old Aug 2, 2011 | 12:57 PM
I just checked that out. I don't think you get the shifter/linkage with it though right?
Old Aug 2, 2011 | 01:01 PM
yloDiscoII's Avatar
I'm in the same boat as you Kalel, no CDL....I sure wish there was a cheaper option. Swapping in a '99.5-'01,'04 T-case seems to be the cheapest, but also has risk involved with buying/installing an "unkown" transfer case.
