CDL dash light on 2000 D2
Old Feb 22, 2018 | 11:47 AM
  #21
Motorhead1's Avatar
whoop whoop
Old Feb 22, 2018 | 12:07 PM
  #22
Best4x4's Avatar
Does it go nuts when you have CDL engaged & shut it off then back on? That is what I had until I swapped the SLABS vs wire cutting. I’m happy as I got the newer SLABS for next to nothing.
Old Feb 23, 2018 | 12:14 AM
  #23
Tito19's Avatar
@Best4x4 nothing crazy happens. The only difference is that the CDL dash light comes on with all the other lights when the key is in the on position.
Old Feb 23, 2018 | 06:12 AM
  #24
Best4x4's Avatar
Both of mine set the 3 amigos at startup & drove me nuts so I swapped the SLABS units for newer ones.
Congrats on the CDL conversion!
Old Feb 28, 2018 | 04:19 PM
  #25
Big Jim Swade's Avatar
If you're going to upgrade your slabs unit from a newer vehicle, you also want to try to get one with or without SLS to match the same as the vehicle your going to put it into. Otherwise it will need to be changed in the vehicles computer with "test book" at a Rover dealership or some other ODB device that can change the SLS setting. Most of the ones on ebay, the seller has no idea if the salvage vehicle had SLS or not.
Old Mar 1, 2018 | 06:39 AM
  #26
mollusc's Avatar
If you're nice to someone with a Hawkeye they might lend you theirs and you can switch off the SLS using that.
turbodave
Mar 29, 2019 07:22 AM
TRIARII
Jan 6, 2017 08:28 PM
primey
Oct 5, 2011 10:06 PM
WaltNYC
Feb 1, 2011 11:20 PM
lipadj46
Feb 11, 2010 07:45 AM
