CDL Question
Old Dec 10, 2007 | 02:59 PM
discotx's Avatar
Default CDL Question
I just started the very addictive modification stage on my '99 DII. (HD OME kit to be delivered today and new tires and wheels installed by the end of week... anyone want to buy some 18's????)
So as I scour all the forums for ideas, thoughts, opinons etc... I ran across a CDL question...
CDL = Center Differential Lock..right?
Did i read correctly that my '99 has the all the "guts" for a CDL but I may not have had that option on the vehicle hence no way to activate it?
Or am I totally confused!!!!
Old Dec 10, 2007 | 03:23 PM
Default RE: CDL Question
Your truck does have a CDL t/case that just needs to have an old D1 linkage hooked up to gain some great traction.
Old Dec 10, 2007 | 03:48 PM
discotx's Avatar
Thanks Mike...I will have to figure that one out...can you point me to a thread that discusses this and discusses what is involved in this mod...etc....
Old Dec 10, 2007 | 04:11 PM
darkside's Avatar
here is a cheap way to do it. https://landroverforums.com/m_18909/tm.htm
Old Dec 10, 2007 | 04:13 PM
Call me and I can send you a picture of where it hooks up to the t/case.
303-862-7680
Colorado between 7 am and 8 pm
Old Dec 10, 2007 | 06:39 PM
tailchaser0527's Avatar
Mike, will the cdl improve traction ona DII if there's no mods to the axels? I've engaged mine one time and got stuck crossing a ditch, unlocked the cdl, trac control kicked in and pulled me right out.
Old Dec 10, 2007 | 09:19 PM
discotx's Avatar
So the expensive way is a kit that hooks up with cables and has a new shifter that takes the place of my current H -L shifter? ...from a 2004? I've seen one on expedition exchange...
Old Dec 10, 2007 | 09:35 PM
I'm pretty sure the most common way, and probably one of the cheapest, is the shifter from a DI. I've seen many other generic ways to do it, but none really look "clean" enough for me.
Old Dec 11, 2007 | 08:20 AM
discotx's Avatar
There appears to be a 2004 retrofit kit on "expedition exchange"..https://www.expeditionexchange.com/discovery/........ scroll down about half way..........does this shifter take take the place of myoriginal one that only shifts from high to low and allow me to not only shift from high to low but lock the diff as well? has anyone done this retrofit with this kit?
Old Dec 11, 2007 | 09:49 AM
You can go to, http://www.roverlandparts.com/index....S&Category=347
and buy either a D1 or the 04 shifter.
