CDL questions/manual locking.
Old Jul 12, 2013 | 12:17 AM
blackpaw80's Avatar
Default CDL questions/manual locking.
I have a '99 D2, and found the nipple for the CDL this afternoon.
I'm definitly going to find a DI or late model to get the actual linkage off, but I'm going on a trip to SW Colorado soon and won't have time before that.
So, for manual use, I want to make sure I've understand this correctly:
1. to lock my CDL, have the motor running, in neutral, and turn clockwise with a 10 mm open wrench about 20 degrees.
2. to unlock the CDL, have the engine running, in neutral, and turn counter-clockwise about 20 degrees.
3. I will lose all traction control if I turn the motor off with CDL engaged, and turn the motor back on again, so I must disengage before turing offthe motor.
4. What do I do if I forget and turn the motor off before unlocking it and lose traction control.
Old Jul 12, 2013 | 07:30 AM
You don't have to do it with the engine running.
Enjoy our great State.
Cal Paul Grant for a good D1 shifter along with a D1 hi/low shift plate for easier installation.
Old Jul 12, 2013 | 08:37 AM
ZGPhoto's Avatar
If you turn the vehicle off and lose T/C, simply unlock the CDL with the vehicle on. Sometimes the light doesn't go away immediately, when it goes off after turning the wheels and moving a couple feet, turn the vehicle off, and back on. You can then lock the CDL again.
turbodave
Mar 29, 2019 07:22 AM
thehun
Feb 24, 2011 09:19 PM
bosshogt
Feb 21, 2011 07:34 PM
lipadj46
Feb 11, 2010 07:45 AM
johanba
Apr 3, 2007 11:37 AM
