CDL shifter
Old Oct 28, 2008 | 01:45 PM
Jull's Avatar
Default CDL shifter
As some of you know I have some major t-case issues. I was wondering how far does the CDL shifter is supposed to go back when engaged in the high gear? I know it might sound like a dumb question... Because I have seen pictures on internet where the shifter is way further back than in my truck. My shifter is stuck, and I'm currently trying to make it work.
I know it can be only a matter of adjustement. But I think this fact can be responsible for my t-case trouble. Or maybe I'm simply paranoid a bit [:-]
Thanks for any input on this!
Julien
Old Oct 28, 2008 | 03:20 PM
Disco2Guy's Avatar
Default RE: CDL shifter
This is in my D2, but the shifter position should be the same. It is in Hi Unlocked.
Old Oct 28, 2008 | 03:42 PM
discoxd's Avatar
when mine is in high in my d1 its kinda straight up... not back... then in low it goes more forward... i will try to get a pic for you later... i just recently just my linkage "unseized"... it took some work and a lot of bolt loosener type spray stuff but its good now...
________
Live Sex Webshows
Old Oct 28, 2008 | 04:19 PM
Disco2Guy's Avatar
Interesting. I have the '04 linkage installed and when I'm Lo Locked the shifter is in about the center position. I didn't realize there was such a difference between the two.
Old Oct 28, 2008 | 07:15 PM
You have shifted it far enough when the warning indicator says you are in gear.
Old Oct 28, 2008 | 09:22 PM
Jull's Avatar
Thanks for the replies. As I was trying to unseize it... I broke the linkage for hi-lo positions ... now I don't know where it was when it broke. I will have ti get it welded back together...
But at least I'm glad to know that the gears were properly engaged on mine.
Old Oct 28, 2008 | 09:26 PM
Disco2Guy's Avatar
That's sucks it broke. I didn't have the link at work, but this might help you.
Old Oct 28, 2008 | 09:30 PM
Jull's Avatar
I know about this page, I read it, printed it and it is in my truck. Thanks Disco2...
Old Oct 29, 2008 | 07:13 AM
discoxd's Avatar
thats the information i used as welll... the only thing i did differently is instead of rivets holding the rubber boot deal on, i put those little plastic screw wedge deals(like the things you put in drywall i think, i wish i knew what they were called) inside the holes where the old rivets were and then used screws to hold it in place... works good and now if i ever need to get it off, it just unscrews...
________
BESTHORNYAMELIA
Old Oct 29, 2008 | 08:02 AM
Jull's Avatar
I think I'll do the same. Maybe not use drywall screws but metal screws. Since I will have to get everything off once again when I will change my t-case.
