CDL shifter elbow needed to bolt to diff?
Old May 5, 2021 | 03:07 PM
oaty's Avatar
Default CDL shifter elbow needed to bolt to diff?
I want to put my existing CDL shifter in my 2000 D2. I have the part(s) except the elbow that bolts on to the diff. Guess I could make one but wanted to see if anyone has one I could buy?
FYI let my disco sit up for a year and it got lonesome. So I got her out and been driving the last few days. Never put the CDL shifter in that I got 2.5 years ago.
Thanks
Oaty
Old May 6, 2021 | 07:48 AM
XRAD's Avatar
do you mean the 'arm' for the diff lock selector or the 'cable' mount...arms are still available from UK (I think I saw them at ashcroft?),,,,sometimes used parts for this pop up on ebay
Old May 7, 2021 | 06:20 AM
mln01's Avatar
Which transfer case shifter are you trying to install? Is it one from an original 1994-1999 Discovery, or is it the style used in the 2004 Discovery that uses cables instead of the levers used in the earlier style shifter?
Old May 10, 2021 | 12:32 PM
oaty's Avatar
I have a 2000 Discovery II. I was given a CDL off another rover. I believe it was at 1999-2004 series. I have the complete CDL shifter except the mounting bracket the fits on the transfer case. The L shaped 2 bolt bracket that holds the cable onto the transfer case under the vehicle not in the cab. I have a picture somewhere. This is not the parts that sit in the cab, this is underneath two bolt bracket. Sorry for the incorrect verbiage.
Old May 10, 2021 | 02:39 PM
mollusc's Avatar
There are two different mechanisms -- one uses direct linkages and one uses cables. The brackets on the transfer case are different for each one.
It does sound like you have a 2004 mechanism though, if you're talking about cables.
Old May 10, 2021 | 11:41 PM
T-rex's Avatar
The lower part there that attaches to the transfer case? I sold a shifter years ago that didn't have that part. The guy contacted me to ask if I had it - I didn't - he then went to the local stealership and they sold him a brand new one off the shelf for $30 I think it was. I gave him a good discount for his troubles. I'd try the dealership. Or if you can get the part number it would be easer to find on line.
Old May 11, 2021 | 01:49 AM
rikkd's Avatar
The cable goes onto the CDL shifter, and the weird slanted L with 2 holes for bolts will bolt onto the top of the transfer case.
Old May 11, 2021 | 06:21 AM
oaty's Avatar
Default I’ll take a pic of my cdl shifter
I am missing another part that turns the shifter as well. By looking at the picture.....
Old May 11, 2021 | 07:49 AM
oaty's Avatar
The part with the arrow is what I first need, also realized that the other circled part is missing. I need both circled parts. If you know part number and correct name for above parts.
Old May 11, 2021 | 03:07 PM
Fallstaff's Avatar
I did mine with a D1 arm, but the equivalent to the small one I just cut out of thick brass. Won't last forever, but it's actually not that much force. And on my 21 year old truck it will probably only be used a dozen times before the inevitable cubing.
