ceiling leak...most likely sunroof?
Old Jul 20, 2011 | 01:08 PM
jrkstore43's Avatar
Do the corner connections look something like this?
>>>DiscoMike - are you saying to seal the corner connection with sealant and not reattach the drain tube?
Attached Thumbnails ceiling leak...most likely sunroof?-img_4910.jpg   ceiling leak...most likely sunroof?-img_4907.jpg
Old Jul 22, 2011 | 03:42 PM
88Mwife's Avatar
it was an actual little box, but we fixed it up with a bunch of silicone so we are going to take mike's advice and leave well enough alone! lol
Old Aug 31, 2011 | 07:59 AM
vtec2403's Avatar
8th Gear
I've got the same leak it seems. When it downpours outside, I notice water in the passenger's sunvisor and map holder, as well as where the passenger's seatbelt connect to the door frame. I've also had water fall out of my rearview mirror at times.
It's crazy. My cloth on my headliner is beginning to become unattached, and hang down.
When I get the time, I'm going to explore the drain tubes and see what I can find. I'm not so sure I'm comfortable with removing the headliner.
Old Aug 31, 2011 | 05:02 PM
88Mwife's Avatar
vtec2403, removing the headliner is a lot of work, but i was able to help my husband with it and we got it out in about 30 minutes. make sure you have a friend help you though, because if you don't the headliner can crack and then you'll have a headliner that doesn't go back in properly. just take your time and don't let your disco smell your fear!!
Old Sep 2, 2011 | 11:49 AM
handsome rob's Avatar
I had a bad leak as well and thought it was the sunroof, but after checking that all out it was fine. The culprit was where the roof rails attached. Water would weep from under the foam type gasket that went in between the two. After tightening it it still leaked so I did a clear silicone all around the gasket on the outside and it has not leaked one bit. If you take your time it is clean and cannot be noticed unless you are looking for it. Good luck.
hilltoppersx
ROAMING WITH FRIENDS
Dec 7, 2010 05:48 PM
VikingDiesel
May 17, 2009 12:45 PM
Nux
Oct 26, 2005 03:43 AM
06RR06RRS
Oct 9, 2005 04:26 AM
bookerbr
Sep 8, 2005 02:43 AM
