CEL help please
Old May 18, 2009 | 08:26 PM
Disco C's Avatar
Default CEL help please
CEL came on today. Throwing codes P0133 and P0420. Backround; 2003 Disco. 60000 mile servie done @62000. Replaced front O2's and complete Y-pipe about 3 months ago. Currently at 70000 miles. Still have a faint engine tick wants it warms up. Have flushed engine, running syn, oil pressure checked and good.
Any advise or thoughts are aprciated. Im in KS and was planning to take my truck to CO next month to play. Not lookin good.
Old May 18, 2009 | 09:07 PM
Why did you replace your "Y" Pipe, hope you got it done under warranty.
Who's 02's did you install, if you had the dealer do this work, you have a 1 year warranty.
Old May 18, 2009 | 09:12 PM
okdiscoguy's Avatar
If you put in your own O2's I would call the manufacturer. Answer Mike's questions and we can help more...
Old May 18, 2009 | 09:28 PM
Disco C's Avatar
I was getting some lean codes awhile back. Had the 2 front O2's changed. Codes reapered a few weeks later. Couldnt figure out what the problem was. Through ignorance and desperation replaced the Y pipe and MAF. Ended up one of the new O2's was bad. that was three months ago. I purchased the Y pipe from AB. Mechanic put in O2's. I think they are Bosh. Mike I was hoping to bring my truck to your fine state for sum fun. Going to the Sangres (Kit Carson) mid june. Hopefully I will not have to rent a car.
Old May 18, 2009 | 09:31 PM
okdiscoguy's Avatar
Do you remember which new O2 was bad and replaced? If you had one go out when new, I would say you still have a bad one drivers side ...
Old May 18, 2009 | 09:38 PM
Disco C's Avatar
It was bank 1. I moved it to the passenger side when I changed out the Y pipe to see if the code would follow. It did, so replaced it under warrenty. Would that bad O2 throw the cat code as well?
Thank you gentelman!
Old May 19, 2009 | 09:10 AM
Disco C's Avatar
Should I clear the codes and see what comes back? Does it do any good to clean the o2 sensers?
Old May 19, 2009 | 11:31 AM
okdiscoguy's Avatar
Ok, so the one that was in the same batch as the one that failed just now failed. Take it back. No good to clean the sensors.
Old May 19, 2009 | 11:45 AM
Disco C's Avatar
Ya that is what I figured. i need to take it to the shop anyway. i wanna take my truck to Colorado but this engine tick makes me nervous. Okdisco were in OK are ya? I work for a company based out of Norman. I am in Wichita, KS.
Old May 19, 2009 | 04:56 PM
Disco C's Avatar
So I cleared the codes today and drove around for 15-20 miles. Light never came back on. Probably a bad O2. I'll wait and see. What ya guys think of me driven to Colorado with my engine tick? Bad idea?
