CEL reset
Old Oct 21, 2006 | 09:28 PM
jmang's Avatar
Default CEL reset
anyone here know how to reset the computer check engine light. it gave me a code for the IAT sensor, saying the sensors temperature has been exceeded. The reason this could have happened is because i installed a new air intake and accidently disconnected the sensor, and while driving down the road..check engine light went on...so i figured out the sensor was disconnected..then i reconnected it...and the check engine light is still on. Anyway i can reset the ecm myself? Thanks guys in advance.
j-mang
Old Oct 21, 2006 | 10:24 PM
Default RE: CEL reset
So what year and model are you talking about, makes a difference?????????????????
Mike
Old Oct 22, 2006 | 04:29 AM
jmang's Avatar
im terribly sorry. its a 98 disco lse. i can also provide the vin number if you guys need it. thanks in advance.
j-mang
Old Oct 22, 2006 | 11:25 AM
You will need to find a shop with a scanner capiable of clearing the codes. If the problem has been fixed, the CEL will stay of, if it is still haveing a problem it will recode.
Usually most shops will charge to clear the faults.
This is the only way to remove them.
Mike
rravenn13
Jun 15, 2007 04:32 PM
scottagnew101
Jun 14, 2007 02:50 PM
97DiscoKid
May 30, 2007 04:07 AM
Jwilk
Nov 4, 2006 01:04 PM
Corsair33
Sep 1, 2006 12:13 PM
