Center console white smoke
Old Jul 12, 2013 | 10:53 PM
mdzdisco04's Avatar
Default Center console white smoke
I can't be any more frustrated with my disco 04. I definitely hate it.
After spending a small fortune replacing the head gasket the starter motor begin to act up. According to the mechanic the antifreeze from the leak of the head gaskets corroded the starter motor, so some times when I go to stat it up I get a like a click, click like the battery is drained.
So today when I went to pick up my kid from day care the car did not start, again with the click, click, I notice quite a bit white smoke coming out from the central console. Definitely something is burnt but I don't know what, windows work, heated seats don't know due to being summer in STL and very hot, electric seats work.
Please help, what can be burnt and is it worth it to look what can it be.
Old Jul 12, 2013 | 10:56 PM
Plenty of things with connections, grounds, wiring headers, in the console. You'll need to open it up. The RAVE electrical circuits manauals and electrical library (pictures) are a great help. Worth it, yes. Possibility of vehicle fire and loss of vehicle, plus home if it is parked in garage.
Old Jul 12, 2013 | 11:50 PM
bballjames's Avatar
X2 There are a LOT of wires that run through there. You need to pull it up to find out what's going on.
Old Jul 13, 2013 | 01:02 AM
mdzdisco04's Avatar
thank you for the help. The future of my disco is not looking good.
Old Jul 13, 2013 | 05:37 AM
If you have anything installed on the truck that did not come from the factory, like a different radio, GPS, lights, etc.; these are places where people cut corners on wiring and fuses.
Old Jul 13, 2013 | 06:06 AM
jfall's Avatar
OH horse poo poo.
You have a bad ground. The ground circuit is going thru your hand brake cable to ground and smoking the cable.
You need to get the braided ground wire from the driver's head to the firewall installed.
Who ever did the heads figured - oh I will leave that wire off. Who needs it anyway. Wrong.
The battery grounds to the chassis. So, does the engine.
If the engine and transmission are not perfectly grounded, then the current when you start the engine will find creative ways to ground - like white smoke from the burning ebrake cable. Which can burn your hand too by the way.
Old Jul 13, 2013 | 06:07 AM
jfall's Avatar
Your heated seats are NOT going to work in the summer. Too hot and the hi limit temp is reached - so the seats remain off.
Wait until all the oranges freeze in the winter then try the seats.
Old Jul 13, 2013 | 07:25 AM
coors's Avatar
Originally Posted by jfall
OH horse poo poo.
He's right. Search for my thread titled: Disco Inferno.
Old Jul 13, 2013 | 09:36 AM
I would call thew mechanic and have it towed back to him, then put a 4 Sale sign on it.
Old Jul 13, 2013 | 10:11 AM
mdzdisco04's Avatar
OH horse poo poo.
I opened the console and the ebrake cable was burnt.
Two questions:
1_ How difficult and or expensive is to replace the wire from the driver's head to the firewall.
2_ How difficult and or Expensive is to change the ebrake wire.
