Center Differential Lock - 2000 Disco II
Old Jan 2, 2012 | 09:25 AM
TripleThreat's Avatar
Default Center Differential Lock - 2000 Disco II
I have a 2000 Disco II with the appropriate parts in the Center Differential to turn it into a Locking Differential with the appropriate linkage and shifter mechanism.
I am aware that Ashcroft makes an aftermarket linkage and shifter mechanism that will bolt right up with a few modifications to the Transmission Tunnel pan cover to accommodate the shifter motion necessary to engage the CDL.
Are there any other options besides spending ~ $500 on the Ashcroft unit? Where there any Disco II's that had the appropriate linkage and shifter that I could try to source the part through a salvage yard at a reduced cost?
Jeff
Old Jan 2, 2012 | 09:28 AM
Sure, use a shifter assembly from a D1 that bolts right up, costing you around $150.
Old Jan 2, 2012 | 09:50 AM
Sweet - Thanks Mike...
I'll start the search...
Jeff
Old Jan 2, 2012 | 12:02 PM
Big Jim Swade's Avatar
This one on Ebay comes out of poland, but it looks pretty good and runs about $320
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Jan 2, 2012 | 04:26 PM
drowssap's Avatar
he goes up every time, mine was $250.00
Old Jan 2, 2012 | 04:32 PM
hilltoppersx's Avatar
My cdl lever cost about $30. Search the forums
Old Jan 2, 2012 | 06:45 PM
bosshogt's Avatar
I just did this last week. Installing the lever is not hard. No one told me it directly bolted into the top of the transmission. (Two different lenght bolts). Just figured that one out. i would suggest cutting the hole big enough so the top shifter bolts do not touch the metal plate to the trans tunnel. it causes vibration and extra noise. I would also add some more foam back to the hole you cut to help deaden road noise. I have to go back in and do this. I found some Dynomat.
If the bolts on the top of the D1 shifter touch that place they make your console vibrate, because there is a direct connection to your transmission. As before you only had a cable so it did not transmit noise and vibration.
There are really no clear instructions on this setup you kinda have to figure it out yourself. But not hard if you are a mechanical intuitive person.
Old Jan 2, 2012 | 08:38 PM
lordmorpheus's Avatar
Get in good with a salvage yard with a 2004 D2 on their lot. I got my '04 shifter with linkage, cables, CDL spigot, handle and boot for $150 + shipping
calebbo
Jan 25, 2013 06:22 PM
dino109
Jan 1, 2012 12:06 PM
Noah360
Sep 6, 2009 10:05 PM
mrossipir
Jan 1, 2009 10:54 AM
audiurq
Jul 1, 2007 11:52 PM
