Center Differential seized?
Old Jun 7, 2009 | 03:23 PM
Noah360's Avatar
Angry Center Differential seized?
Hey all,
I've got a Land Rover recently bought and i couldn't shift the diff. into low or lock.
So i took it apart with what i had, and i can get it into low now. i can also shift it into lock. However, in order to get it into lock, i have to use a screw driver to push it over. I hanv't put it back together yet. So my quetions is, do stock differentials have to be pushed down then shifted over as a saftey device or how can i un-seize this common problem? Also is there a lock for the 4 high aswell? Thanks so much!
-Noah
Old Jun 7, 2009 | 03:31 PM
Torancis_LR's Avatar
I had the same problem this morning. It seems to have some resistance. But if you move the diff locks stationary, make sure you are on Neutral. If not, have the truck ease in walking pace then shift to N to lock.
Hope this helps.
Old Jun 7, 2009 | 03:34 PM
Noah360's Avatar
well i have had it at the recommended 1-5 mph to engage and still having difficulites. What is causing this resistance and what can i do to fix it? Thanks
Noah
Old Jun 7, 2009 | 04:16 PM
Noah360's Avatar
Default Update
K, more specifically now
With the cover completley off i can see the problem
i can sucesfully move the gear to the left (lock) but when i go to bring it over to the right again to unlock the lever on the right that pulls the locking mechanism away doesn't move. I see there is a spring in the unit, but i cannot push down or pull up. Am i suppose to be able to push down to switch from gear to gear
Old Jun 8, 2009 | 03:25 PM
Noah360's Avatar
bump!
Old Jun 8, 2009 | 03:40 PM
khuds308's Avatar
what vehicle are you working on? DI or DII? and please retype what your issue is. I don't understand what exactly the problem is. forget the springs and crap. what is the truck NOT doing.
Old Jun 8, 2009 | 03:44 PM
khuds308's Avatar
https://landroverforums.com/forum/sh...ad.php?t=22521
see if that helps
Old Jun 8, 2009 | 05:52 PM
Lube everything that moves, lube the hell out of it and then work it loose.
Old Sep 6, 2009 | 04:41 PM
cst756's Avatar
Originally Posted by khuds308
All the help I need.
Old Sep 6, 2009 | 10:05 PM
hazletbassist89's Avatar
ohh the imagery.
calebbo
Jan 25, 2013 06:22 PM
TripleThreat
Jan 2, 2012 08:38 PM
dino109
Jan 1, 2012 12:06 PM
mrossipir
Jan 1, 2009 10:54 AM
audiurq
Jul 1, 2007 11:52 PM
