Centering ball??
Old 09-23-2009, 12:05 PM
LebaneseShowoff's Avatar
Default Centering ball??
Ok, so my buddy gave me his old DS to rebuild but he started taking it apart and lost the spring and ball and i need a new one... where do i buy this?? i tried Atlantic british but nothing.
Old 09-23-2009, 12:09 PM
Any auto parts store, try a Percision 617 or cross reference it.
Old 09-23-2009, 07:35 PM
antichrist's Avatar
If it's a stock propshaft it's Precisoin 617 or Neapco 7-0081NG
Old 09-28-2009, 09:53 PM
ok, the spring was there... i had the Centering ball already but i was frustrated because i couldn't get the old one out, and i still can't. Can anyone tell me how? I've searched all over the net and nothing!! i found this forum in the UK and they used a slide hammer. i used one and had no luck.
Old 09-28-2009, 10:03 PM
lipadj46's Avatar
http://static.scribd.com/docs/tkatf9...IAL_VIEW=width
Slide hammer seems to be the way people do it.
Old 09-29-2009, 08:09 AM
Chrisinhouston's Avatar
I'm curious about the last step mentioned where he advises to remove the grease zerks and install ones that are cut off and pluged shut. I would assume it is so you don't break them off while offroading. What is the consensus? Do others do this or not?
Old 09-29-2009, 08:54 AM
antichrist's Avatar
I don't. I use flush fittings.
Old 09-29-2009, 09:16 AM
I think I've seen these somewhere. You use a grease gun type injector needle if I remember correctly. What size fittings does the LR take? Is is a standard one or some kind of obscure British pipe thread size???
Old 10-27-2009, 05:38 PM
mydisco03's Avatar
Very nice!!! but insted of doing that i replace that drive shaft for the discovery 1 and work perfec!!! just replace the transfer case flanch and thats all... $30 fixs
Old 10-27-2009, 07:51 PM
A D1 front shaft won't last long in a D2 because of the angle. Better make plans to replace it soon.
Quick Reply: Centering ball??
