Centering ball - front drive shaft Disco II
Old Nov 27, 2008 | 08:15 AM
Default RE: Centering ball - front drive shaft Disco II
ORIGINAL: humroot
Here you go...I found them for you.
Precision 417 or Neapco 7-0081NG
The Percision should be a 617, not a 417 and they are easily found on line when you Google u-joints.
If you use the 617 then also buy the Percision 344 u-joints for a matched set.
Old Nov 27, 2008 | 09:33 AM
humroot's Avatar
My bad. Sorry about that. Yes, that would have sucked to get the wrong part! I went back and changed it so I do screw anyone up if they do a search later.
I would have a driveline shop lined up just in case. Sometimes it is impossible to get the center ball out without a torch to cut it. I had the driveshaft out and one of the u-joint already in. The driveline shop did the centerball and the other 2 u-joints, balanced and painted for $50. Totally worth it. Good luck...let us know how it goes.
Old Nov 27, 2008 | 09:47 AM
ORIGINAL: Night Train
Sorry - forgot to ask, my Disco is a 2004 is the shaft the same as say the 2000?
Thanks Again
Robert
No, it is a slightly different length but uses the same u-joints.
Old Nov 27, 2008 | 10:08 AM
Urban Panzer's Avatar
A slide hammer gets the centering ball out no probs andI personally dont think itmatters at allwhich ball / u-joint comboyou use tbh. I used GKN ones in mine. If they fit they will do the job.
Old Nov 27, 2008 | 08:26 PM
Night Train's Avatar
Man - just when I thought I was getting a handle on this situation humroot (no offense) goes and throws a wrench in the gears. In the past I have changed uuuuu lets just say alot of u-joints, never re-manufactured a driveshaft in the manner I'm about to. I have also broken u-joints off road but, those only destroyed themselves and banged the surrounding area a little - NEVER took out a transmission, THATS why I'm doing this as soon as I get all this stuff (knowledge) processed and the stuff (parts) come in. But, humroot mentions having the shaft balanced after the work is done, I have never heard of this - I've also never owned a double cadigon (sp) that didnt have a carrier (would not fly far). Does the shaft have to be "balanced"?
Thanks for all the input
Robert
Old Nov 27, 2008 | 09:15 PM
humroot's Avatar
Just make sure you mark the shaft where it goes together on the double cardon joint so the shaft goes back together the same way it was. I marked mine, but after hours with a slide hammer, chisel, propane torch, etc. the marks came off. I couldn't get the center ball out of mine and had to take it to a shop anyway. If you can get everything put back together the way it came apart, and you didn't have a vibration when you started, you should be good to go. I really couldn't tell you why mine was so hard to get off, most folks don't seem to have a problem. I'm sure I'm the exception and that yours will go fine.
Old Nov 28, 2008 | 09:16 AM
humroot,
Cool Beans - thanks for the response. I should (hopefully) be good to go. Something I have already done (was taught to me by an old Trail Guide after my first shattered u-joint) is use a Dremel Tool with a cutting wheel to run a scribe line across all the separation points of a drive shaft including the output and pinion flanges. However, although doing this seems to have saved me from problems after the fact, I never knew problems could be encountered by "just changing a u-joint!
Thanks for the information and patients
Robert
Old Nov 28, 2008 | 11:17 AM
If you mark your drive shaft and put the u-joints in with their jerks facing opposite direction, you won't need to rebalance the drive shaft.
br0keit
Jun 16, 2012 09:17 AM
barsa
Dec 14, 2010 08:07 PM
phil29
Oct 7, 2010 10:26 AM
lordmorpheus
Jun 6, 2010 07:28 AM
jw928
Feb 28, 2009 10:26 PM
