CHANGE ECU and CLUSTER.
Old Mar 23, 2022 | 12:03 AM
muffin man's Avatar
Default I'll know this tomorrow.
Originally Posted by Alex_M
Ok, for an '01 to '03 or vice versa you will also want to change the MAF sensor and intake box lid. They are different sizes.
Are both of these trucks equipped (or unequipped) with SAI?
SAI it is unknown.....tomorrow
Old Mar 23, 2022 | 03:53 AM
Extinct's Avatar
Originally Posted by muffin man
ok....really is interesting data. thkkk......what is the IC ???
Instrument cluster
Old Mar 23, 2022 | 08:02 AM
ahab's Avatar
When I did this with an 04 donor into an 03 truck (both 4.6 w/SAI) I didn't know about the IDM sync. I must've had the ignition on for ~20m because there were no issues. I swapped ECU, BCU, TCU, SLABS, trans/transfer case, cluster, ignition and driver's door (because the 03 had no fob) and so far it's been 17k trouble-free miles. The only hiccup was one year I forgot to tell the inspection station that the VIN stored in the ECU would not match the paperwork, he got a little excited about that.
Old Mar 24, 2022 | 09:53 AM
muffin man's Avatar
Question ???
Originally Posted by Extinct
Instrument cluster
the elements to change would be: ecu, bcu, excitation coil in the key.
when you say IC do you mean where the odometer is installed?
Old Mar 24, 2022 | 10:06 AM
muffin man's Avatar
Talking .............
unequipped !
Old Mar 24, 2022 | 11:50 AM
muffin man's Avatar
Default NO.
Originally Posted by ahab
Isn't that a 4.0 to 4.6 conversion as well?
no, it is a problem of immobilization of the unit. change harness parts. for start.
Old Mar 24, 2022 | 11:52 AM
muffin man's Avatar
Talking ok
Instrument cluster
ok. is neccesary for odo. investigate this. I only have the issue that when changing the IC the aesthetics are different between models. but it does not matter
Old Mar 24, 2022 | 11:53 AM
muffin man's Avatar
really is very interesant this change. provides new knowledge.
thak all!
Old Mar 24, 2022 | 02:41 PM
mollusc's Avatar
You should not need to mess with the key or the key coil. Just change the entire instrument cluster.
Old Mar 24, 2022 | 08:46 PM
muffin man's Avatar
Thumbs up parts harness
yes, the best way!I have 2 controls already repaired this afternoon.....and tomorrow is the big day. if they don't work...change parts
