CHANGE ECU and CLUSTER.
Old 03-24-2022, 08:52 PM
muffin man's Avatar
Smile about this.
Originally Posted by mollusc
You should not need to mess with the key or the key coil. Just change the entire instrument cluster.
if the original key of disco final is bad..........I will have to change the excitation coil, to use my remote control and that the bcu and my ecu detect the disarmed alarm signal. yes the IC it will change.
thk !
  #22
Old 03-25-2022, 06:40 AM
mollusc's Avatar
thk !
There is nothing in the key that registers with the vehicle to make it run. The key can be completely mechanical and still function normally, including disabling the alarm.
If your original key remote does not work, new keys can be programmed to work with the existing system. Swapping the fob recognition may not be as simple as changing the RF unit, which I believe is behind the overhead liner near the rear view mirror
muffin man (03-28-2022)
  #23
Old 03-28-2022, 11:24 AM
muffin man's Avatar
ok. kit complete for change in my disco 2 03.........the parts were changed and it started without incident. I took a long trip to the beach and a good day. thanks for your comments
cammyr01
03-24-2022 12:22 PM
clint70
11-06-2019 05:43 AM
willys_49
11-10-2012 07:42 AM
Quick Reply: CHANGE ECU and CLUSTER.
