CHANGE MOTOR 4.6 V8 to 4.0 V8 DII
Old Mar 8, 2022 | 10:50 PM
muffin man's Avatar
Default CHANGE MOTOR 4.6 V8 to 4.0 V8 DII
HI....is possibbile change a motor in a disco II 2003 4.6 v8 to 4.0 v8 ??
Old Mar 9, 2022 | 07:14 AM
adalton's Avatar
Im sure it possible but why would you want to? The 4.6 is a major upgrade over the 4.0.
Old Mar 9, 2022 | 11:34 AM
Brandon318's Avatar
Actually, I have both and prefer the 4.0. Could also be asking because of an engine replacement and 4.6s not being as widely available as 4.0s.
That being said, it's possible for sure - but someone can chime in to correct me - the frames are different. I'm not 100% confident what makes them different, but I think it has to do with the mounting location of the transmission and maybe some other mounting points in the engine bay.
Old Mar 9, 2022 | 11:35 AM
gleepglorp's Avatar
Not when your 4.6 is about to blow up
Old Mar 9, 2022 | 11:49 AM
Richard Gallant's Avatar
Engine mounts are exactly the same but I am not sure about transmission - but it is not likely to be a major issue.
Old Mar 9, 2022 | 11:56 AM
adalton's Avatar
Havent had issues with mine knock on wood. Hoping for many more trouble free miles. 😂
Old Mar 9, 2022 | 02:17 PM
Harvlr's Avatar
Aren’t the blocks the same? Changing a GEMS to a Bosch is a bit more work.
Old Mar 9, 2022 | 03:16 PM
whowa004's Avatar
blocks are the same but the earlier 4.0s seem to be built to tighter tolerances and as the d2 production continued on they didn't replace the tooling as the LR3 was set to debut. I haven't seen or heard the 99 or 00s have near the liner issues that 03/04s did...maybe that's not provable but it is a narrative that's been suggested here on numerous occasions. If you had time and wanted a project, take a 4.0 block from a 99 and swap in 4.6 bits with a fresh cam and enjoy. If we could tune the these easier then these motors would really benefit from head/intake/exhaust work but having to ship an ecu to the UK as the only option makes that extra money probably not worth going down that rabbit hole.
Natanael Prendi
May 6, 2021 01:18 PM
robadob
May 2, 2018 07:51 AM
MaineDisco2
Nov 1, 2016 09:08 PM
nzoliver
Dec 28, 2008 07:37 PM
herblatham
Jun 21, 2008 08:19 PM
