Changed batter...now Celcius?
Old Jul 10, 2007 | 07:45 PM
SpeedAgent's Avatar
Default Changed batter...now Celcius?
I just put in a new battery and my climate control reads in celcius. How do I change this back to F?
Old Jul 10, 2007 | 08:21 PM
Default RE: Changed batter...now Celcius?
Start you truck and hold down the power button and the recirculation button at the same time till it changes.
Mike
Old Jul 11, 2007 | 07:05 AM
SpeedAgent's Avatar
will do, thanks!
Old Jul 11, 2007 | 07:29 PM
SpeedAgent's Avatar
That didn't work. I tried a number of combinations, but nothing works. When I turn the ac on the celcius symbol comes up briefly, almost like it's giving you the option to change to F, but nothing changes it.
Any suggestions?
Old Jul 11, 2007 | 07:53 PM
StevenDiscoII's Avatar
After you turn truck on, turn off A/C, the press A/C Power button simultaneously withAir RecycleButton (extreme left / right buttons),
hold," C°"appears in the digital screen on the left," F°" appears on the right, then A/C will turn on with" F°" as default, release. [sm=smiley20.gif]
Old Jul 11, 2007 | 07:57 PM
robdis96's Avatar
Your owners manual should have how to change from C to F.
Press and hold air recirculation button
at hte same time press and hold on/off button for 3 seconds
it will beep and convert
If that doesn't work I don't know what will
Old Jul 11, 2007 | 11:21 PM
NOTE: I have changed my above post: The right button to press is as Mike said "Air Recycle", however, perhaps the steps to be taken are little different. I had to re-set my display from Celsius to Fahrenheit just this weekend after I had blown the F20 fuse during change to the headliner panel. It worked fine for me.
https://landroverforums.com/m_31309/tm.htm
Old Jul 12, 2007 | 07:34 AM
SpeedAgent's Avatar
I found my manual and fixed it. The AC system must be on- press and hold the recirculate button and then press and hold the power button at the same time, both F and C come up and within three seconds it switches to the opposite of what is already set.
garydebergerac
Jul 18, 2015 10:50 AM
Alex_M
Feb 8, 2015 01:41 PM
yarddawg
May 18, 2010 08:30 PM
96Bronco
May 14, 2010 11:32 AM
rhino
Jan 13, 2008 04:19 PM
