Changed battery and won't start!
Old Sep 18, 2017 | 02:47 PM
pilsner's Avatar
Default Changed battery and won't start!
I already checked the SEARCH function but did not find my exact problem .
2000 disco 2
191k
installed a new battery and now it will not start: will crank but not start.
no blinking lights on dash
tried to reset the inertia switch under hood and reset alarm with key fob
no luck!
ran great until I removed battery (so IDK why it would be a sudden failure of the CPS).
all other electronics work fine (locks, stereo, etc).
battery connection is tight
HELP!
Old Sep 18, 2017 | 05:54 PM
No Doubt's Avatar
Disconnect the battery for 15 seconds, then when you reattach the positive cable make certain that it doesn't hit/miss as you are attaching (in other words, press it on hard and smooth without ever breaking the connection even briefly as you attach+tighten).
Then try to restart motor.
Old Sep 18, 2017 | 06:38 PM
No Doubt's Avatar
If the above doesn't reset everything and work, next notice that you have more than one red wire and more than 1 black wire going to your battery terminals.
Wiggle those. Inspect thoroughly for a cable break.
vtec2403
Jan 30, 2013 05:27 AM
Sanriogonz
May 23, 2012 11:27 PM
lively
Feb 23, 2012 12:15 PM
V.haggard
Jan 31, 2012 01:44 PM
dh42891
Jul 26, 2010 12:37 AM
