changed the idler pulleys...still squeaking
Old Nov 19, 2015 | 10:56 AM
ge234's Avatar
Default changed the idler pulleys...still squeaking
new power steering pump, new water pump...not sure where the squeak is coming from. any ideas?
Old Nov 19, 2015 | 11:34 AM
Alex_M's Avatar
Have you tried replacing the serpentine belt? There's also the possibility of the AC condenser, but in my experience that makes more of a clicking sound most of the time.
Old Nov 19, 2015 | 11:43 AM
ge234's Avatar
hey alex, the belt is brand new...the AC unit and the alternator are old...I will listen to both of them tonight, thanks for the idea.
Old Nov 19, 2015 | 12:19 PM
cappedup's Avatar
Did you do tensioner as well?
I did all three and it was the tensioner at fault. Seemed like a lower quality item
Old Nov 19, 2015 | 12:21 PM
Alex_M's Avatar
I assumed you were including the tensioner when you said idler pulleys, but capped is absolutely right. Seems to be the cause of a lot of peoples squeaks.
Old Nov 19, 2015 | 01:38 PM
ge234's Avatar
tensioner was done with the other two...three new pulleys, i dont get it!
Old Nov 19, 2015 | 02:02 PM
Alex_M's Avatar
Well then it's almost definitely either the Alt or the Condenser. I know I only mentioned the condenser, but I... well, I totally forgot about the Alt for a second. I'd actually guess Alt over condenser.
Old Nov 19, 2015 | 02:22 PM
ge234's Avatar
its a 99 and the alternator is original...so i should probably change it. alex, do you sell them?
Old Nov 19, 2015 | 02:35 PM
Alex_M's Avatar
I had one off a parts truck, but I've already sold it. If you're going to be running lots of electronics/big stereo/winch/lights/etc then you could upgrade to a P38 alternator also. I believe they put out an extra 20-30 amps.
Old Nov 19, 2015 | 02:44 PM
ge234's Avatar
nothing like that...i barely listen to the stock radio...so all i need is a replacement...think i can find a used on on ebay?
