Changing battery in key.
on
1 Post
All right, just checked my Rave cd and it says that your door lock/fuel pump cut-off switch located on the engine compartement passenger's side firewall (looks like a little rubber flashlite) needs to be reset. To reset it, you have to press the top of it downward and release.
Then go try it all again and get back to us.
Well, I did reset the door lock/fuel pump cut-off switch in the engine compartment and it did not help. If I put the key in the door and turn it once (not twice), it locks/unlocks not only the drivers door, but all the doors at once. When I turn the key to lock it, the yellow hazard lights flash and the little red light starts blinking inside indicating the alarm is armed.
I did learn today though, that the dealer I bought it from had to replace the ignition because the key got stuck in the ignition and would not come out. Maybe that is the problem?
nelsontod
05-15-2012 10:25 AM
xtina01
09-19-2011 04:10 PM
arrkerr
12-14-2005 10:06 AM
