Is changing coolant every year too often?
Old Feb 28, 2010 | 09:51 PM
Tapper's Avatar
Default Is changing coolant every year too often?
Reading all the head gasket stuff makes be nervous. Is changing the coolant every year over kill?
Thanks
04 SE, 70K
Old Feb 28, 2010 | 09:55 PM
lipadj46's Avatar
No not in my mind. You are right to be paranoid.
Old Feb 28, 2010 | 09:56 PM
sloppyjoe's Avatar
some would say yes,,others no.
i say if you have the time, money and know how to do whatever you like and not to worry what others think.
Old Feb 28, 2010 | 10:13 PM
Tapper's Avatar
thanks for the quick replies
Old Feb 28, 2010 | 11:13 PM
tornado_735's Avatar
I heard a great analogy the other day:
"I've never, in my entire life, heard of someone having a failure from changing their [insert automotive fluid here] too often." In this case, the automotive fluid we were talking about was oil, but I'm sure it would work with just about any fluid that you can dump in a car.
So have at it!
Good luck,
Aaron
Old Feb 28, 2010 | 11:15 PM
BajaXJ92's Avatar
Its your money, so yes!
Change your vehicle every 3,000 miles if you can afford it!
Old Mar 1, 2010 | 10:21 AM
The nice thing about changing it that often all you need to do is a drain and fill.
Remove the lower radiator hose, come back a hour later, put it back and refill and bleed the system.
viperdriver
Feb 10, 2010 06:04 AM
Freelanderfree
Freelander
Mar 28, 2008 11:04 AM
Max_A6
Mar 5, 2008 08:52 AM
huckleberry
Dec 3, 2006 02:12 PM
abethlen
Jan 9, 2006 09:12 PM
