Changing Diff Oil
Old May 25, 2010 | 06:59 PM
Originally Posted by range_time
why ice maker lines? The breathers i have on my other 4x4 are just soft rubber.
Also if you are going to put a new one on think about extending it way up high in case of a deep water crossing.
Dave
Because it is dirt cheap.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I have not used it but others have with good luck.
Old May 25, 2010 | 08:00 PM
aemnky606's Avatar
Its cheap and it works very well. also was able to use the old hold down clips.
Old May 27, 2010 | 10:15 PM
Danny Lee 97 Disco's Avatar
Originally Posted by Spike555
You may not see any actual leaking, but it may be wet around a seal.
You will need to remove the axle breather and make sure it is clear.
Do you have any pics of the axle breather?
Old May 28, 2010 | 06:40 PM
http://www.roverparts.com/Parts/FTC2176.cfm
That is the whole thing, the metal part screws into the top of the axle, drivers side.
Remove the tubing, using a 9/16? socket unscrew it.
Make sure you clean up the area around it before you take it off so dirt and junk does not fall into the axle housing.
Pay attention to how the tubing is routed and take note of the clips.
My clips broke so I just used zip ties keeping them loose so the tubing can move around if needed.
dusty1
Dec 7, 2014 01:57 PM
mwindth
Dec 21, 2010 08:28 AM
chad420
Jul 25, 2009 10:49 AM
Disco2Guy
Jun 20, 2008 10:13 PM
