Easy ABS fault reset
Old May 27, 2010 | 07:27 PM
greg409's Avatar
Default Easy ABS fault reset
First, I don't know if this will work on a DII
I've had an intermittent abs light that I've used to keep my wife from driving my truck.
I repacked my hubs recently, so I reseated the wheel sensors and decided to perform the "blink test"
I jumped the OBDII, it seems to have worked, as I cannot get the abs light to trip now.
If you DI owners search the net for "abs blink test" or "abs fault reset discovery"
you'll find the procedure & code #'s
I hate typing, so you're on you're own, it worked on my '97 DI.
http://www.horodecki.pl/rajdy4x4/ABS...ng%20light.pdf
luck,greg
Old May 28, 2010 | 09:11 AM
Wish something like that would work on a D2 but it won't.
Old May 28, 2010 | 01:02 PM
greg409's Avatar
This looks interesting
http://www.rswsolutions.com/index.ph...d=56&Itemid=55
luck,greg
Old May 28, 2010 | 08:45 PM
lipadj46's Avatar
Originally Posted by greg409
Yes that has been around for a while now. If it were as easy as jumping a connection then there would be no need for one of them there doohickies.
06Range
May 8, 2013 09:01 PM
jmason
Mar 12, 2013 08:08 PM
Rich 00 DISCO
Dec 29, 2008 03:25 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
