Changing differentail fluid tomorrow ..... advice
Hey guys. I was thinking about changing my differential fluid tomorrow for the first time (not the first time for the truck, but rather my first time doing it) and I was wondering if anyone could give me some advice. I wanted to know what is the best brand of oil to put in and what grade. Also wanted to make sure that there aren't any gaskets that I need to do this service. Finally, is this something that I can do in my driveway with minimal tools. I appreciate the help.
RE: Changing differentail fluid tomorrow ..... advice
Usually a drain and fill plug, drain it all, and fill to the plug ..
what grade ? I am not sure, but a simple phone call to your dealer will answer all questions you just asked.
If you replace a gasket it's because you took the dif cover off. If you do that you dont need to remove the drain plug.
If I was changing the fluid i'd change the gasket and look at the gears, since it's full time 4 wheel drive, more use ...
so i'd check the teeth.
Pull the drain plug and the fill plug, let it fully drain for 10-15 minutes. Clean off the drain plug, there will be residue and metal shavings on it. Replace the plug and fill w/ the synthetic gear oil of your choice, I use mobile 1 75w/90 gear oil. Fill until you get a constant bead of oil coming out of the fill hole and then plug it up.
on
Manual calls for an 80 to 90 weight gear, 1.8 qts for each diff and I think 2.4 for the t/case.
I go heavier, using an 85W/140 weight for extra protection on our older gears.
Also as for a brand, Rover says use a synthetic, such as Royal Purple, Mobil 1, Lucas or one of those.
You will need to use a 1/2" ratchet with a 2" extension to remove the plugs
seamuspg
03-15-2009 02:16 PM
