Changing Headlamps 2003 Discovery
Old Aug 4, 2008 | 12:15 PM
Bob2003Discovery's Avatar
Default Changing Headlamps 2003 Discovery
The owner's manual would probably tell me how to do this but ... I lost it.
How do I change headlamps? (these are the H7 Halogen style) I took a quick look under the hood and it's pretty tight in there. Is there an easy way to do this? (ie without removing anything else) and, after I am done will I have to re-aim the lamps?
Thanks,
Old Aug 4, 2008 | 03:23 PM
Sfef84's Avatar
Default RE: Changing Headlamps 2003 Discovery
you HAVE to remove the grille. There are three rivet screws on the top of the plastic grille... unscrew them and lift the grille off. There are two hexbolt screws on top of each headlamp assembly and one to the right (if looking at the passenger side headlight assembly) or the the left (if looking at DS headlight assembly). unscrew them, wiggle the entire thing out, unhook the wire connection box and there you have it...
Old Aug 4, 2008 | 03:33 PM
All that to change a bulb? Geez.
Thanks for the info.
Old Aug 4, 2008 | 05:40 PM
Sfef84's Avatar
Yup.... you are preaching to the choir
Darover
Feb 8, 2009 06:50 PM
paleo
Jun 2, 2008 03:29 PM
ajh
Dec 20, 2007 11:18 PM
jp32781
LR2
Dec 14, 2007 11:44 AM
ajh
Oct 8, 2007 06:54 AM
