Changing lower intake gasket
So I need to change the lower intake gasket to repair the coolant leak. Mike, I looked under the hood and it does not have the extra A/C thing you were woried about. Looking for recomondations as to where to purchase the parts online and also if their are any particular things to look out for, as I will be doing the job myself(saving the 2400.00 the dealer wants). I'll also be changing to wires to the ones reccommended here in the forums while it's apart.
Thanks,
Brian
Thanks,
Brian
1 ERR7306 GASKET - VALLEY - NEW STYLE
$29.95 $29.95 [/align] [/align] 2 9218B INTAKE GASKET KIT (BOSCH)
$109.95 $109.95 [/align] [/align] 3 9206MAG IGNITION WIRE SET - MAGNECOR PERFORMANCE ELECTROSPORTS WIRES - 7MM
$139.95 $139.95 [/align]
There is also this one, any prefrence?
GASKET VALLEY NEW STYLE
Item: LKJ500020
In Stock! $44.95
Item: LKJ500020
![](http://www.roverparts.com/images/in_stock_g.gif)
on
I would rather see you buy there valley pan gasket kit that includes all seals from the valley pan and up including new v/c gaskets.
I would also suggest asking them for the actual intake manifold gasket that goes between the top and bottom manifold.
Also order the 8 mm Magnecor wires not the 7's, if they don't have them then call Tony at 650-365-4145 and get them from him.
Just in case you don't have this already make sure you have all the torque specs you need for the lower and upper intake bolts. When I had to do the same job, My friendly dealer wasn't so friendly on giving me the specs and held me up for a day because "they were busy"
bagocheetohs
08-11-2015 06:13 PM
bcolins
06-29-2013 09:25 PM
