dash backlights WTF?
Old Mar 13, 2008 | 06:52 PM
franklips's Avatar
7th Gear
Default dash backlights WTF?
Alright, so it started with some tail light problems on my 97 disco, when i fixed i blew the fuse for the tail& headlights. I replaced the fuse and now the backlights for my gauges/climate control don't work. I checked all fuses they seem fine. Anyone have anyanswers?Any help would be much appreciated, this is driving me f!@#ing nuts!!!
Old Mar 13, 2008 | 08:31 PM
Default RE: dash backlights WTF?
Cab you ask a question without swearing, If so you might get some help.
Old Mar 13, 2008 | 09:15 PM
okdiscoguy's Avatar
X2 on what Mike said. This isn't d-web.
I assume you have checked the rheostat on the dash that contols the brightness to see if there is power there?
Old Mar 13, 2008 | 09:30 PM
Camdisco24's Avatar
X3 on what make said as well, this forum has class, and we will do anything we can to help, without sounding trashy.
Anyways, if all the fuses are good (double check), you need to check all the connections running to the dash. If anything looks strange let us know. Sometimes the electrical stuff on these things has a mind of its own. One thing could be fixed and the other would break because the thing you fixed caused it to not work... who knows. Just check everything closely, and try that brightness **** under the steering, sometimes it gets moved but I dont think it blacks it out completely...
Old Mar 14, 2008 | 05:58 PM
franklips's Avatar
7th Gear
I appologize for the language I guess the frustration is getting the better of me.
Old Mar 14, 2008 | 06:39 PM
Camdisco24's Avatar
No worries, you are new! But get back to us if you continue to have this problem, unless you are electrical you might need to have someone go take a look at it. These trucks have the strangest electrical problems...
Old Mar 14, 2008 | 06:41 PM
jkid's Avatar
Never let inanimate objects get the better of you. You are smarter than they are, hopefully. If you know which fuse sends power to it, try swapping it out with one that you know doeswork, you never know it may only look good. The only real way to findthe problemis too just keep looking for 12v down the line and find out where it stops.
nic1641
Sep 6, 2011 11:13 PM
jw928
Dec 19, 2008 01:06 AM
discoverMT
Feb 17, 2008 08:57 AM
GrnRover
Feb 8, 2007 02:41 AM
cassie11
Aug 31, 2006 01:46 AM
