Changing lower intake gasket
Old Mar 3, 2008 | 12:28 PM
dragon_avaloch's Avatar
Default Changing lower intake gasket
So I need to change the lower intake gasket to repair the coolant leak. Mike, I looked under the hood and it does not have the extra A/C thing you were woried about. Looking for recomondations as to where to purchase the parts online and also if their are any particular things to look out for, as I will be doing the job myself(saving the 2400.00 the dealer wants). I'll also be changing to wires to the ones reccommended here in the forums while it's apart.
Thanks,
Brian
Old Mar 3, 2008 | 01:35 PM
Default RE: Changing lower intake gasket
Go to Atlantic British and order there complete valley pan gasket set as well as the intake manifold gasket. You then might want to order a set of Magnacor wires, since with the manifold off you can change the wires easily. When you get everything shout.
Old Mar 3, 2008 | 03:53 PM
1 ERR7306 GASKET - VALLEY - NEW STYLE
$29.95 $29.95 [/align] [/align] 2 9218B INTAKE GASKET KIT (BOSCH)
$109.95 $109.95 [/align] [/align] 3 9206MAG IGNITION WIRE SET - MAGNECOR PERFORMANCE ELECTROSPORTS WIRES - 7MM
$139.95 $139.95 [/align]
There is also this one, any prefrence?
GASKET VALLEY NEW STYLE
Item: LKJ500020 In Stock! $44.95
Old Mar 3, 2008 | 04:15 PM
I would rather see you buy there valley pan gasket kit that includes all seals from the valley pan and up including new v/c gaskets.
I would also suggest asking them for the actual intake manifold gasket that goes between the top and bottom manifold.
Also order the 8 mm Magnecor wires not the 7's, if they don't have them then call Tony at 650-365-4145 and get them from him.
Old Mar 12, 2008 | 02:53 PM
Purchased the gasket kit from British and the 8mm wires and plugs from Tony, British does not carry them. Should arrive by Monday.
Old Mar 12, 2008 | 11:29 PM
CHITOWNALEX's Avatar
8th Gear
Just in case you don't have this already make sure you have all the torque specs you need for the lower and upper intake bolts. When I had to do the same job, My friendly dealer wasn't so friendly on giving me the specs and held me up for a day because "they were busy"
Old Mar 14, 2008 | 01:27 PM
Sure are a lot of parts in this box.[]
Old Mar 14, 2008 | 01:45 PM
Plugs and wires are here now too. Is their any need to check the gap on the Bosch Platinum +4 plugs?
Old Mar 14, 2008 | 02:10 PM
NO, you don't have to gap the Plus 4's.
Let us know how it goes.
bagocheetohs
Aug 11, 2015 06:13 PM
jpmiller
Sep 26, 2012 06:32 AM
charcoal grey
Mar 14, 2009 07:16 PM
jkid
Nov 8, 2008 01:42 AM
