changing plug wires
changing plug wires
If I have to already pull off the driver's side exhaust manifold for replacement, would that afford me enough space to go through that way to replace plugs or will that not effect much going through that side? Also, is there a very driving reason for using the magnacore $100 wires or can one use the more standard set?
2000 Disco 152,000 miles. Yes, just getting started on the 60,000 service list because I don't know its history.
I'll second what Mike said...you're only gonna want to do the wires once. Even if your headers are already off it won't give you any extra room. It's possible to change the wires without taking many things off, but its a PITA. I had no experience at all and was able to take my upper manifold off and have plenty of room.
xtina01
09-19-2011 04:10 PM
