Changing Spark Plug Wires Disco II
Posted: Sat Jul 27 2013, 10:20PMI didn't need new wires but in case I do need in the future I will go this route. Hope this helps for those that have to do wires in the near future.
If it works, great. So all of this with exhausts hooked up, etc.? Bet you could also do a fuel pressure test more easily as well.
For those who have not had the pleasure, here is a view from the rear.
Also, has anyone simply found a different place to mount the coil packs that don't require either lowering the engine or removing the top end to access? I would happily buy universal wires for the life of the vehicle if I did not have to deal with the current set-up.
I do but the sai is held on by a combination of 6 small bolts and some hoses, its all very easy to work around. I know having the coil packs up top would make it easier but in there current location they are protected from water when fording and how often do you actually change plugs? 60k miles/ 5 years? Its not too bad.
