Changing valve gaskets..
Old Nov 3, 2009 | 01:33 PM
hollis's Avatar
Default Changing valve gaskets..
I wanted to know if this job is very technical or can a medium level mechanic do it? Thanks..
Old Nov 3, 2009 | 02:07 PM
jycsalas's Avatar
you mean valve cover gaskets right?
I have done it and I would consider my self LESS than a medium level mechanic....
Just follow RAVE and keep track of all your parts, take pics and that's it.
Why do you need to replace them?
Old Nov 3, 2009 | 02:57 PM
NiteTrain's Avatar
do it on a saturday, it's not a job you want to start after work and need to drive the rover the next day. intake has to come off.
Old Nov 3, 2009 | 03:15 PM
mwindth's Avatar
You will need to replace the intake plenum gasket as well
Old Nov 4, 2009 | 09:39 AM
If you are changing them because they leak, have you tried tightening them first, the 2 bolts always vibrate loose which causes a leak. Try tightening them first and then power scrubbing the engine with cold water to get a clean engine.
If you still need to replace the gaskets, also plan on installing a set of 8 mm Magnacor wires at the same time, a lot easier with the intake already removed.
Old Nov 6, 2009 | 01:49 PM
RoverRookie's Avatar
Ballpark anybody?...how much will an intake valve gasket job hurt through the neighborhood mechanic... Thanks - RR.
Old Nov 6, 2009 | 02:34 PM
NiteTrain's Avatar
If I had to guess I'd say parts and labor...$350
Old Nov 6, 2009 | 02:38 PM
So, have you tried tightening them yet???
Could save you a lot of money if they are loose.
Old Nov 9, 2009 | 01:18 PM
04BluDisco's Avatar
I second the notion to try tightening first... Had my car for a year now and running it on Mobil 1 synthetic... I tried tightening a couple times, but now I have no leaks on the valve cover gaskets.
Big Jim Swade
Sep 13, 2012 07:27 AM
RROJ
Mar 26, 2011 02:37 PM
rtubbs
Nov 28, 2009 03:38 PM
dezlpower
May 4, 2009 12:17 AM
tailchaser0527
Apr 18, 2009 09:38 AM
