Charging Problems
Charging Problems
Hi All, I have a strange problem on my 95 Auto V8, the charge light goes out on start up, but only showing 11.5 volts at the battery with the engine running. Have checked all the fuses, all OK. My question is, isthis definately the alternator or should I be looking somewhere else??
Thanks in advance
Neil.
Thanks in advance
Neil.
RE: Charging Problems
If this just started happening then I would say yes, it is the alternator going bad. Check your belt tension first, with the engine off push on the belt, is it tight?
You should start with the belt, if it is really worn replace it, if it is slipping the battery wont charge.
