Charging Problems
Old Jul 22, 2008 | 08:20 PM
nce1500's Avatar
Default Charging Problems
Hi All, I have a strange problem on my 95 Auto V8, the charge light goes out on start up, but only showing 11.5 volts at the battery with the engine running. Have checked all the fuses, all OK. My question is, isthis definately the alternator or should I be looking somewhere else??
Thanks in advance
Neil.
Old Jul 22, 2008 | 09:25 PM
Default RE: Charging Problems
If this just started happening then I would say yes, it is the alternator going bad. Check your belt tension first, with the engine off push on the belt, is it tight?
You should start with the belt, if it is really worn replace it, if it is slipping the battery wont charge.
Old Jul 22, 2008 | 10:15 PM
jkid's Avatar
What is your voltage readingat the battery with the engine off? Have you had starting problems? 11.5 volts would be a pretty dead battery.
Old Jul 23, 2008 | 08:18 AM
If your belt is tight and all your connections are clean and tight then it is time to run down to the local auto parts store and get it tested. You should have voltage from 13.6 to 14.4 volts.
christians1600
Jun 19, 2009 03:35 AM
steve
Feb 18, 2009 12:02 AM
bonedoc
Jun 13, 2007 03:24 PM
sabsr1954
Oct 24, 2006 04:25 PM
RTLimo
Aug 15, 2005 12:42 AM
