Check Engine Light and codes.....
Old Apr 15, 2013 | 12:05 PM
03DiscoTwo's Avatar
4wd High
Default Check Engine Light and codes.....
Hey everyone...
2003 LR Discovery w/ 4.6 with 107,000 miles....CEL came on last week with the following codes thrown and screened by Autozone......P0154 (oxygen circuit, no activity bank 2) P0174 (Bank 2 system too lean) P1415 (no info) and P1174 (no info)
Engine has a rough idle (500-700 rpms) but does not stall out. I see a lot of posts about O2 sensors and also plugs and wires. Any direction and/or help is greatly appreciated
Cheers,
Jay
Old Apr 15, 2013 | 12:12 PM
jeffh's Avatar
replace your upstream O2 sensors. clear the codes and go for a drive.
Old Apr 15, 2013 | 01:47 PM
Ghaniba's Avatar
+1 - upstream o2 sensors are adjusting your fueling. Rough idle and throwing an o2 code it'd be the first thing I swapped.
Dave
Old Apr 15, 2013 | 02:51 PM
jfall's Avatar
easy.
O2 sensor on passengers's side.
Front one - pull it out.
Replace it with BOSCH only.
Get on on amazon about $65.
Clear all codes.
and drive.
Old Apr 16, 2013 | 10:51 AM
03DiscoTwo's Avatar
4wd High
Thanks again....will try and update asap...
Old Apr 26, 2013 | 01:15 PM
03DiscoTwo's Avatar
4wd High
Quick update - swapped out front O2 sensor and problem appears to be solved. Runs much smoother and codes cleared. Thanks again for everyone's assistance.
My friend has the same model with only 67,000 miles on his. He just replaced the exhaust from cats back. Now he is receiving a 0420 code. Is that the rear o2 sensor?
FlyingZebra34
Feb 22, 2014 05:39 PM
ycc456
Oct 28, 2013 12:43 AM
cobbcj7
Mar 14, 2012 04:12 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
