Check Engine Light stays on
Old Dec 9, 2008 | 01:18 PM
JBEGIN's Avatar
Default Check Engine Light stays on
99 DII 137,000 miles....I put in 2 new O2 sensors on the drivers side, and the check engine light stays on, took it for a good ride every day for 3 days and its still on... what am i doing wrong? do i need to check my codes and delete them and drive it or what? i dont have an obdII but i
can go borrow my mechanics and read them,ill report baCk with the codes. i need to have the light go off so i can get an inspection
Old Dec 9, 2008 | 02:05 PM
hazletbassist89's Avatar
Default RE: Check Engine Light stays on
Let us know what the codes are. I'm gonna take a stab in the dark and say it will probably be plugs and wires. Don't buy anything else till you have new codes though.
Old Dec 9, 2008 | 05:10 PM
You need to replace all of your O2's at the same time.
And like hasslet said, what codes are you getting?
Old Dec 9, 2008 | 09:42 PM
JBEGIN's Avatar
P0134 oxygen sensor no activity
P0135
p0155
I had my mechanic read the code(s) in the computer, they were P0134 No sensor activity... he cleared the code and it stayed off for as long as i had it running... after stopping to get gas, back on the road again the light came back on... im sure its the same code comin up.
Old Dec 10, 2008 | 12:57 PM
JBEGIN's Avatar
so my Service Engine light is back on, inspection is due, i assume that the code is the same as before, P0134 no sensor activity
Old Dec 10, 2008 | 01:09 PM
With your mileage, all 4 02 sensors should be replaced, then drive and have the faults cleared.
Old Dec 10, 2008 | 01:34 PM
JBEGIN's Avatar
okay, ill look into getting the 2 sensors for the other side... so after installing these, that no activity Code should go away and not come back after clearing?
Old Dec 10, 2008 | 07:23 PM
Yes, once you correct the problem and clear the code you will be good to go.
MichaelDisc02
Feb 26, 2015 04:56 PM
texmbr
Nov 27, 2010 12:14 PM
dankdistrict
Jan 28, 2010 11:10 PM
Rover_Hokie
Jan 8, 2010 10:49 PM
jjballer1
Aug 23, 2009 05:33 PM
