Check oil light
Check oil light
Yes I know not a good judge using that but this is what is happing. When engine warms up and your at idle the light comes on. Rev the engine a bit goes away. When light is on I get more ticking (I do have a liner tick). Now when the light is coming in the exhaust starts smoking and it does smell like an engine that is running rough with some oil burning.
i do have a new oil pump and gaskets coming next week and will be taking the pan off and cleaning it all up.
there is no change in the coolant level in the reservoir btw
liner tick ? What is your coolant temp ??
I had it to when I got my disco but it had the oem stat Once I kept temps below 200 it went away
i would physically check oil pressure to confirm if it’s pressure issue or sensor or wire.
But never a bad thing to change out oil pump etc
Do you have a copy of the RAVE manual? These engines have their oil pumps sandwiched in the front timing cover. You'll be dropping the pan anyway, and it's a good idea to replace the o-ring on the oil pump pickup tube while you're in there, but this job is a lot more involved that a simple oil pump replacement on some other engines where you drop the pan, swap the pump, and button it back up.
The Deputy (05-02-2020)
Here's what I ordered:
1 x UltraGauge EM Plus v1.2 (UltraGauge_EM_Plus v1.2_15)
Mounting options Horizontal Surface Mount & Bracket
